How to create a graphic window schedule
well, i wanted to know : i want to create a type of lists that describe windows around a building.
the lists include for each window an elevation(graphic one of the window itself) H&W, type(as a general description), some more general-text remarks, location ect.
the only info that i need the window to have from the plans and elevations is : u.k. ,hight, width and the graphic description.
each window - in an a-4 ussualy format
the problem is that people here explained me how to create a schedule- but when i use first the in-program schedule - its not what im looking for but the list that looks like what im looking for.
sorry ,but im new to archicad (:
2 Replies 2
ok in short im lokking to know if there is a way to make a custom list as you can make a custom schedule (:
It is really important that your subject line have something to do with your question - not "here I am again", OK? 😉
No, you do not want lists, but do want schedules still. See the attached screenshot: you want to add one of the symbolic views to your schedule. (And, then of course change the text to Hebrew...other thread.)
