How to export a drawing from an Archicad layout to AutoCAD?
Viktoria Moscow
How to export a drawing from an Archicad layout to AutoCAD? We need a stamp and a frame in dwg.
1 REPLY 1
Gordana Radonic
Community Manager
Hi @Viktoria Moscow
The best is to create a dedicated Publisher Set and use the Organizer to set all the layouts you want to save in DWG within that Publisher Set (on the left side of the Organizer choose Layout Book, on the right choose the new Publisher Set you've created, select layouts from the left you want to add to the publisher set on the right, or drag and drop them). In the Publisher Set properties you can set the publishing location and within the set you can choose DWG format. Check these
Hope this helps,
Gordana
Gordana Radonić
Community Manager
