How to import texures in 3ds files to Archicad 13
I have been pulling my hair out trying to import materials, colours, textures, etc that belong to 3ds files into AC13.
Once imported, the object looks grey, when I try to change the material, the entire object is changed. How do I do this successfully - I have looked at a a previous post, and it didn't work.
Please help.
Thanks,
Hayley.
12 Replies 12
It sounds like the parts are set to a single "override" material rather than using the internally defined ones. You need to deselect this override in the Info box or Settings Dialog to enable the internal materials.
3DS objects typically import with multiple materials that you can find in the parameters within the settings dialog. These sometimes have useful names but often do not so that figuring out which is which can be a bit of a pain (ie trial and error).
So far I have not worried about the textures. There may be a way to get them to read automatically but I haven't investigated this. I assume that you can modify or create a material to use the texture and then apply it in the appropriate parameter. This may also require setting the texture origin in 3D depending on the circumstances, though this could be tricky.
Dwight
You might also consider checking the box "Use Object's Materials."
Dwight Atkinson
Just to be clear this is what I meant when I referred to the override settings.
Dwight
Right. So be clear next time.
Dwight Atkinson
Yeah - no posting in cryptic messages like Dwight does
Dwight
Barry brings up a good point. That, to be useful, answers should be short, specific, action-oriented and use Archicad-specific terminology.
Dwight Atkinson
Thanks for your replies.
When converting the 3ds to gsm, I have lwft the box 'Import Hidden Obects' & 'Use texture's alpha channel' ticked. Once converted, I have left the 'Use objects materials'. The result is black with shades of grey whereas ths original is wicker coloured.
Any ideas?
Thanks.
ps. I appreciate all replies as I have been in the dark on this issue for ages and was beginning to think that no-one would reply.
Dwight
Send me the info to download the object and i will solve it.
Use PM
Dwight Atkinson
Thanks Dwight,
I have attached the 3ds file as requested.
I don't know what a PM is - sorry.
Ta,
Hayley
