IFC elements rotates in module
Mats_Knutsson
I have an IFC model from struct which opens fine in AC. I save as .pln and hotlink it into my projekt and several elements are rotated, see attach. Any clue? The lower figure is the IFC opened in AC and the upper figure is the weird one. The arrow indicates a TT-element that seem to have rotated around it's insertion point. Several other similar elements are also rotated. Very strange since the model look really good when I open the IFC. It must be something with the IFC and hotlinking!?
/Mats
AC 25 SWE Full
from which program structure was exported?
That's rather troubling. I had trouble a couple years ago with structures imported from Revit doing similar rotations but that was in the initial import and it has not recurred since then.
Wait. I can think of a possible cause. If you already have the profiles existing in the file you are importing to the rotation angles may be different from the source files. I have seen this happen. Try importing to a clean file (hold option/alt to get "New and Reset" under File>Open). If this works properly you should be able to fix things by deleting the problem profiles. They should be replaced from the source on updating. If not you might need to reimport.
