IFC for complex walls
HI everyone,
I have a problem with IFC in complex walls! How can I create a complex wall with different IFC in each component?
Thank you in advance!
1 Reply 1
I am not exactly sure what your question is, but in the IFC Translation Setup Dialog, in the Export Options panel, click the Conversion Options button.
Then in the upcoming Dialog check the Explode Composite and Complex Profile elements into parts checkbox.
When the project is exported, you will be able to select individual skins of Composites and individual components of Complex Profile elements.
