IFC - resizing IfcBeams?
I've searched the forums here, and I think i know the answer already, but here goes anyway:
Is there a way to easily resize IFC objects in Archicad 10?
I imported a timber frame IFC I created in another program, and although it looks great, I can't seem to stretch my IfcBeams to make them longer. I seem to be able to make them taller, but not longer.
When I go into the "Object Selection Settings" for the IfcBeam, "Custom Settings" is grayed out.
Any thoughts? or am I "stuck with what I got?"
Thanks,
Manny
AC 10
Win XP
lots o'ram
2 slammin 19"-ers
smoke is literally pouring out of my tower it's so jacked!
5 Replies 5
. . . also, the multi-level-marquee will move, but not stretch the IfcBeams, even when I select "stretch" from the "Edit + Reshape" menu.
Manny
TomWaltz
It's not just IFC objects. No library objects in Archicad can be stretched with the Marquee tool.
Simple elements like walls, slabs, roofs, etc. can, but not object based ones like doors, windows, & stairs.
Tom Waltz
thanks . . . i thought so.
Manny
Djordje
Can you resize them by inputting a new length paramater?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
Only if they are all the same length when you are done.
It's like any object, if they offset or are at an angle, you are out of luck
Tom Waltz
