‎2010-10-18 10:31 PM
‎2010-10-20 01:54 AM
‎2010-10-20 06:00 AM
‎2010-10-20 07:33 AM
NandoMogollon wrote:Hi Nando, that's interesting to hear, i thought Canada might have been a head of South Africa - great to hear they are supporting it.
I used it in the company I used to work for in Southafrica. That's a yes.
Here in Canada, still waiting to see it hapening. Maybe yes, since it is Revit territory.
‎2010-10-20 08:14 AM
owen wrote:It's slow but it has become better. However you don't push the button very often. It's only when you actually want to communicate a revised version to/from your partners in crime. But opening a fully modelled IFC-file from MagiCAD is a nice time to have a cup of coffee and chat with your friends.
Using it ...
export / import processes on large projects to be excruciatingly slow (i would say unworkable if there were any alternative)
cheers,
owen
‎2010-10-21 08:25 PM
‎2010-10-21 09:50 PM
Chadwick wrote:Ok so which software were you using, revit, bentley?
We tried to use IFCs on a project where we were teamed up with another firm that uses ArchiCAD. It did not work out. Its nice to know that IFCs are progressing but its not a realistic option at this point. Too much information is lost or doesn't come through as 'smart'. We are definitely keeping an eye on it though...
‎2010-10-22 12:37 AM
‎2010-10-22 12:43 AM
Chadwick wrote:thanks, yes that seems to be a common problem. eg it takes your model & essentially simplifies it (eg lose data). which in a lot of cases is still fine. I guess the different softwares also have different import/export engines to...
Revit Architecture 2010. We'd have windows that would appear solid, doors in different places. Plain old geometry wasn't showing up correctly much less the information in the different components/families.
‎2010-10-23 06:42 PM
owen wrote:Which version of ArchiCAD are you using? (Your sig line says 10+.) The IFC translation has gotten a lot faster, especially in 14.
I have found export / import processes on large projects to be excruciatingly slow
‎2010-10-23 07:00 PM
Chadwick wrote:Some of what you describes sounds like it could be fixed with a little prep of the templates/file settings.
