IFC4 Schema, Archicad Building Materials and ED Catalogue
davdelven
When you export an AC composite, formed by different skins with its own Building Material definitions, you only see the "Name/Description" and "Thickness" when you check the IFC model on a viewer.
In another side, Archicad has its own Material Catalogue (XML file) in order to use it in the EcoDesigner tool (or energy evaluation), linked to Building Material database, but without transferring those properties to IFC Scheme.
At the same time, in Graphisoft AC20 help guide appears (see attached image) the information about TAG and CATEGORIES data of Building Materials are shared as standard IFC Material properties.
The PSets of IFC4 Schema "IfcMaterialProperties" are this: http://www.buildingsmart-tech.org/ifc/IFC4/final/html/schema/ifcmaterialresource/lexical/ifcmaterial...
My question is: Does Graphisoft intend to associate this XML file and its data with the standard Property Sets of IFC 2x4 Schema ?
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
Ruben V
This 'general' question/problem generates a similar specific problem for me - discussed here: https://archicad-talk.graphisoft.com/viewtopic.php?f=12&p=294263#p294263
(sorry for picking up old topics and kind of hijacking them, but either I'm missing out on some basic setting, or David's question is still very relevant... - admin can merge topics if this is more appropriate)
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
1 REPLY 1
Ruben V
(òÓ,)_\,,/
www.studiov2.be
BIMcollab ZOOM
>>> Read my book!<<<
