IS Headline Settings
Laura Yanoviak
When I originally set up this IS, I wanted the first three schedule fields to appear in the headlines -- I think I did this via Headline Settings... -- I have since eliminated schedule field three, and want to use the first two schedule fields as a headline. When I revisit Headline Settings... I am only given the option to use "The first schedule field", which does nothing. Once one merges more than one field into a headline, can that not be redefined? Am I going to have to recreate my IS?
18 REPLIES 18
Laura Yanoviak
Barry wrote:
Could you please show us an image of your new schedule so we can see how you want the headings and can compare to your first image?
Here is a screen shot of the re-created IS, along with the limited options within the Headline Settings dialog.
Laura Yanoviak
Here is a screen shot of a brand-new IS -- note the multiple options in the Headline Settings. I can't figure out at what point the options become limited -- I've tried Sending & Receiving and rebooting AC, but I still have multiple options in the brand-new IS, but limited options in the IS I created yesterday. I have not tried shutting down completely, maybe when I have the time...
Erika Epstein
I couldn't reproduce the problem on PC, didn't try the mac, but Murphy's law it will happen as soon as I finish this post.
I was wondering, in the headline when you have more than one field, if it is in bold you have a comma between, if not bold a period. Where is this setting?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
This distinction does not occur in AC11, maybe this is new in AC12? In AC11, there is no setting to control the "delimiter" (or the character between the two fields) -- we run a Find and Replace in Excel to get rid of them.
Erika Epstein
Laura wrote:
"delimiter".
Thanks, I didn't know what it was called. I used AC11 to match your problem. Hmmm
Where are you running the find & select?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
Excel -- as we all know, IS formatting is very limited -- these FF&E schedules are exported to a pre-formatted Excel template, and the worksheets printed and included in the Specifications.
Erika Epstein
OK, thought you were doing it in AC.
Is there a way to edit this in AC?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
Not in AC11 -- AC12, I don't know.
Thank you Laura.
I thought you could only use the first field as the headline.
I can see a use for this already.
Laura wrote:
I can't figure out at what point the options become limited...
I can't be of much help here.
The only time I have just the option for the first field is if a schedule only has 2 fields in total - which is obviously not the case with your schedule.
