Hi Jeff,
Sort of. Even with the old Windows OLE thing, what you saved from Excel is what showed up in PlotMaker. If you didn't save the changes, they didn't show up. So, saving a PDF isn't that much more. I never did write any script to do it automatically though as hinted at in the old post below.
Note, that there are a few things that can make the hassle of having to use Excel (summarized well in your other post) not quite so bad for repeatedly updated schedules:
You can set up a Publisher set that publishes your raw data to one or more CSV files.
You can Import the CSV file into a worksheet in your Excel workbook using the data import feature of Excel in a way that you can quickly update that sheet after each Publish. Your actual schedule would be in a separate worksheet in the workbook and would have formulas that grab the data from the imported-from-csv sheet, so that you can maintain your formatting as desired. You'd have to delete rows, or insert rows and copy-down formulas as the length of the table changed.
(If you import into your actual schedule, if there were new rows published, you would over-write your summary row(s).)
When you import a csv file into a sheet, set it up to save the query def in the worksheet - this lets you refresh the data subsequently (see next post)...
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
