Anita D
Import export between Archicad and Tekla
hello, We have a problem with improving the coordination efficiency between disciplines, such as inserting IFC files exported from Tekla into Archicad. We would need these elements to be inserted as a group, but with the possibility to edit them.
What would be the most efficient method for overlaying or replacing models based on files that are continuously updated during a project, where more and more types of modifications are discovered over time due to interventions on existing buildings?
Operating system used: Windows 28.6200
Setup info provided by author
1 Reply 1
One method would be to have a dedicated Archicad file into which you import the IFC files. You can make the editing in that file. Then you can place the file as a Hotlink Module into your main Archicad Project file.
