‎2003-11-06 06:29 PM
‎2003-11-06 07:06 PM
‎2003-11-06 09:17 PM
ArchiCAD, as well as many other 3D oriented applications, cannot read AutoCAD solids...You can do it in ArchiCAD 8.1. It allows you to convert solids into meshes..
‎2003-11-06 10:20 PM
‎2003-11-07 12:38 AM
‎2003-11-07 02:52 AM
‎2003-11-07 03:28 AM
‎2003-11-07 04:12 AM
‎2003-11-07 08:44 AM
David wrote:You are right
I must disagree. We are talking about AutoCAD "Solids" not ArchiCAD "Solid Element Operators". AFAIK - AutoCAD "Solids" are not transferable into ArchiCAD.
I quote from the ArchiCAD Help File:
"ACIS, REGION, 3D SOLID
The basic implementation of the DXF add-on does not support them."
I just double-checked by creating some basic Solids (Cube, Sphere, Cylinder) in AutoCAD and tried importing the DWG into ArchiCAD as an Object. "No 3D elements found."
If you have been able to import AutoCAD Solids into ArchiCAD please explain how.
‎2003-11-07 10:50 AM
Ben wrote:Not a work around. That is a method.
The tutorial that Thomas posted is to date the only work around
