‎2019-04-03 02:21 PM
‎2019-04-05 01:24 PM
‎2019-04-05 02:17 PM
‎2019-04-05 02:29 PM
Erwin wrote:Hi,
When you set up properties they can be text (string) or a numerical value. Make sure you have your excel cells set up in the same way (text / value).
Also make sure the properties are assigned to Element Classifications.
‎2019-04-05 02:38 PM
‎2019-04-05 03:05 PM
Erwin wrote:Yeah I have the ID's and zone number etc in the schedule, these are all fine when its exported to excel. The excel document has all the correct information. Its the final step of importing the excel file which gives this message 'Nothing to import - No property values are selected or none are valid for import'
We had some issues with this before and those two things were the culprit I believe.
I also recall some issue with the schedule being a saved view, but not currently having the correct settigns for the view. You see a (!) on the tab if this is the case.
Do you have any 'standard' fields like element ID or zone number in the schedule as well? We ussually have these kinds of mass import / export schedules for zones and those work well.
Maybe try assigning the properties to all elements (not just zones)?
‎2019-04-08 09:52 AM
‎2019-04-09 11:56 AM
‎2020-03-27 11:21 PM
‎2020-03-31 10:54 PM
