giuseppe wrote:
Hi! This what I get when I try to import the file.
Thanks
Must have a lot of 3D trees and things from the landscape designer maybe? I've not seen that message with just architectural things...
You'll have to open the file in SketchUp to see what's going on and determine either (a) what you can omit, or (b) how you can re-save the file in pieces with different elements turned on so that the resulting SKP files have a low enough poly count for the import.
If the file is an older version of SketchUp, you can still download SketchUp Make 2017 for free to do the above. Make is discontinued after 2017.
https://www.sketchup.com/download/make
If it is a 2018 format file, you'll have to use the browser-based SketchUp Free:
https://www.sketchup.com/products/sketchup-free
If you have slow internet, it take a little while for the app to load into the browser. To upload your file, you use the associated free Trimble Connect cloud storage.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
