Importing Revit IFC in ArchiCAD, elements translated as object.
A Lot of elements converted as object after importing from Revit IFC. I need all elements in same properties like Wall, door, window, roof and curtain wall. I think there is some geometry translation issue. Please see screenshot.
When you merge the IFC files you will see a 'Settings' button.
This will allow you to choose an appropriate IFC translator.
You need to choose a translator that does not convert the geometry to objects.
You can also create your own translators with the settings you want.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
From your signature, I assume you are using Archicad 22.
This is controlled by an IFC Translator setting: depending on the setting, elements in the IFC file will be converted to their native ARCHICAD equivalent, to Objects, or to Morphs.
Go to the "File > Interoperability > IFC > IFC Translators" Dialog. Select a Translator in the "Translators for Import" list on the left and click the ... button to the right of the "Geometry Conversion" field.
The "Building Elements" field controls how elements are converted during import. Make sure it is set to the first or second option, in which case Archicad will convert all IFC elements to their native ARCHICAD equivalent whenever possible.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
Hi, Gurus!
I'm new in ArchiCAD, about a month, and may don't understand this software due to experince with it. Recently I exported *.rvt file and converted it to *.IFC file. When I opened it in ArchiCAD I found missing elevations, colors and all sheets. 3D view is looking good but i cannot make any changes on it due to kind of lock which popsups everytime when I highlight wall or window. Any idea how to correct it or I made some mistakes during convertion *.rvt - *.ifc?
Your advice and direction will be very help full for me. Thanks.
