2017-06-02 07:15 PM
2017-07-05 02:30 PM
2017-07-06 07:49 PM
2020-02-29 12:37 AM
2020-03-02 03:01 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-02-04 10:58 PM
2021-02-05 10:42 PM
Lotlock wrote:Save it as a .3ds format file in Rhino and then use the 3ds import addon in ArchiCAD to bring it in and you can set the size upon import if it doesn't look correct with the figures it tried to import it with.
I have saved a selection in rhino as a .3dm file and imported it into Archicad 20 through 'merge' and the library. The object is however slightly scaled larger. I have tried re-import and it all results in a slightly scaled object. What more can I try to solve this issue?
Best regards,
2021-02-10 04:08 PM
cpuello wrote:Hello,
I am having the same issue with archicad 24 and 23 and I try to open a rhino file with archicad 24 or 23 and both archicads keep crashing.
Minh Nguyen
GRAPHISOFT
2021-02-18 04:52 AM
2021-02-18 10:46 AM
murazikberniece wrote:Hello,
I’m on ArchiCAD 22/Rhino 6 now, and the workflow doesn’t really seem too seamless.
ArchiCAD 22 does not support Rhino 6 natively so I am exporting as Rhino 5 everytime. Then I go over to ArchiCAD and import the 3dm as a library. The problem here is that ArchiCAD doesn’t seem to update the geometry afterwards, even if I export an updated model from Rhino to the same file name. I thought that ArchiCAD should detect changes in the library and then update accordingly, but it doesn’t. I want to update the model in rhino dynamically, so that I can plug it into my archicad file
I have downloaded the Rhino plug-in from the graphisoft website, but it does not support rhino 6 againgeometry dash
Should I appropriate the grasshopper-rhino-archicad-live-connection for this? I assume that ArchiCAD 23 should fix compability but is there a solution that works for you meanwhile?
Minh Nguyen
GRAPHISOFT
