‎2005-11-22 07:31 PM
‎2005-11-22 09:19 PM
‎2005-11-22 10:04 PM
‎2005-11-30 09:18 PM
ArtGJr wrote:Of course you do, as the 3ds is triangulated surface geometry.
I still get triangulation lines on all faces using 3ds.
‎2005-11-30 11:55 PM
‎2005-12-02 09:46 AM
ArtGJr wrote:Yep, if you want to use something, you should have it first
I assume I would have to own MaxonForm to do that. Or is there a plugin available like for 3DStudio?
ArtGJr wrote:I might be wrong, but OBJ is still alive AFAIR. Another reason for MaxonForm ...
From formZ I can export the model in: 3DStudio, Art•lantis, DWG, DXF, FACT, IGES, Lightscape, Lightware, OBJ, RIB, SAT, Shockwave W3D, STL, 3DGF, 3DMF, VRML. Don't know how many of these are of any use to get the model into ArchiCAD. DWG, DXF, and 3DStudio are no good for my needs.
ArtGJr wrote:Matter of taste and familiarity ... ZOOM for me was always cryptic and hard to use. As long as you know how to use something, it will seem to you more powerful than something else that is nominally more powerful, but works in a different way or is just not easy to use or learn. People do swear by Cinema4D, that MaxonForm is the modeling part of.
Now Graphisoft is pushing MaxonForm, which from my review of it, is still no formZ or even close, except for it's tight integration with ArchiCAD.
‎2005-12-07 07:22 PM
Djordje wrote:Yes, I've loaded AddOns.
Yep, if you want to use something, you should have it first .........You do know how to load API AddOns, don't you?
Djordje wrote:AFAIR?????????
Djordje wrote:Checked out Cinema 4D, downloaded a demo. Certainly different from formZ. Don't know if it can provide the boolean operations (union, intersection, difference) with the ease of formZ. Of course i've been using formZ for ~10 years.
Matter of taste and familiarity .... People do swear by Cinema4D, that MaxonForm is the modeling part of.
Djordje wrote:Tried to post multiple attachments, but could only attach one. Is it possible to post an image into the reply other than as an attachment? Was trying to show the overall timber frame model and a couple of individual timbers from that model with their joinery.
BTW, what are the shapes you are getting into ArchiCAD? Screenshot? Rendering? Let us know
‎2005-12-07 07:24 PM
‎2005-12-09 05:53 PM
‎2005-12-25 08:43 PM
Djordje wrote:Djordje, the timber framing that is possible with FrameWright and the ArchiCAD tools you mention will not provide me with the degree of joinery detail that I include in my frame models. Over the past 16 years to model the timbers in 3D I have used AutoCAD with AME, Microstation's Modeler and currently formZ. Ashlar-Vellum is another program that I've looked at but not used or tried.
Not that I am any expert on timber framing, but many of the people here are.
Try FrameWright from Encina. Look for user Ralph Wessel - he is one of the authors.
AFAIR means As Far As I Remember😉
I am rather sure that with the standard ArchiCAD library, TrussMaker and Roof wizard you can do all of this easily. Someone should show you how, of course.
