Archicad and Calculation menu
I wonder how many ArchiCAD users really need/use the calculation menu.
I myself ,although i know how to use it (it took me 2 days to learn it), i have never really need it or ,even more, use it.
23 Replies 23
TomWaltz
we use is daily. It's great for door and room finish schedules.
Tom Waltz
Most firms I know are at least using the IS to generate preliminary door and window schedules.
The calculate functions offer much more of course, but the learning curve is steep.
We, too, use it in our office regularly.
I actually wrote custom Listing Templates (TXT files) to fit our needs. Its syntax is documented, it is about as complicated as a more complicated GDL object.
Do you know where to look, or can you provide a step by step example of how to do this?
Thank you
TomWaltz
Thank you
Try this:
Tom Waltz
TomWaltz
...and continued here:
Tom Waltz
TomWaltz
This assumes a simple company template that has all the font & color stuff preset, which is referenced here as "KA-Blank" schedule. The attached screen shot shows the screen you can set that up in. It's for formatting and appearance only, there is nothing else in the template file.
Tom Waltz
Thank you Tom Waltz
"Senior" helper!
I use the interactive schedules to show cost analysis and schedules for finishes and windows and doors. i also do wall schedules to figure the amount of sheetrock and trim is needed in a house. it works well for me and i just modify the info that is there already to help me do what i need.
