‎2011-09-15 04:09 PM
‎2011-09-15 05:49 PM
‎2011-09-15 06:51 PM
Matthew wrote:Raymond,
I haven't tried using properties parts (with desriptors and such) in the interactive scheduler. It may be possible but for full access you will need to get into the intricacies of the list editor etc.
If you are doing much of this I strongly recommend getting Eric Wilk's book "From CAD to Quantity Survey". The advanced quantities features of ArchiCAD are quite complicated and he does an excellent job of breaking it down and making it understandable.
It is available in both the original french as well as in english translation. You may have to get it from your ArchiCAD reseller. It's not widely circulated.
‎2011-09-21 01:07 PM
‎2011-09-21 05:45 PM
Mon wrote:Nothing has changed in the Calculate menu / list schemes since version 6.5 so there should not be any problem applying what is in Wilk's book to any version of AC from 6.5 through 15... Maybe some dialogs look a little different, but not sure which parts you are thinking of that are "quite" different?
Anyways, this book by Eric Wilk is based on the Archicad 9 platform, and i am working in 12. the interface is quite different, i don't get to follow his book step by step. Every now and then i go back and refer to the Graphisoft User Guide to find out how those commands and steps(which are in Archicad 9) are done in Archicad 12.
‎2013-01-29 10:38 PM
