Is Archicad compatible with 3Ds max or Sketchup?
hi there,
ive tried to export a Archicad file(3D model) into a DWG and bring in into 3Ds max, but the model is only show as a 2D plan rather than the whole actual file. so im wondering is a 3d Archicad file can actually work in 3ds Max and sketchup.
hope someone can confirm this to me. thanks
6 REPLIES 6
Export as 3DS.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Srinivas
Karl wrote:
Export as 3DS.
Janice,
FYI you have to be in the 3d window to export as 3ds, maybe that's what you are missing.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
thanks for the information.
it would be helpful if you can give me some tips on how should i export it to get the best result
i.e.
archicad object
element types/material
layers/material
material
thanks for your help.
Srinivas
I prefer to export the model via materials as it gives option to change the materials easily in Max.
Some notes by Graphisoft on conversion units.
http://www.graphisoft.com/support/archicad/archiguide/unitsin3DSformat.html
Also here is a plugin that will help you, not sure if it works with the latest version.
http://plugins.angstraum.at/archicad_wiz/index.htm
ArchiCAD Service
Mac, Windows 11
thank u very much... it is works.
I also tried to save out a 3ds file for import into sketchup but the 3ds file that is saved is simple text format? Could anyone tell me what I am missing here?
Thanks, Paul.
