LINUX: ArchiCAD 13 in Virtualization
Hello.
I have some updated info (though no hard stats yet)
Installed various distros of linux-based OS's and ran VMWare's Virtualization to check out ArchiCAD 13's performance VMWare has implemented cutting edge 3D ability...).
So far, looks tolerable.
It works just fine, and real-world performance is passable.
I have a few different systems and will give some basic rundowns.
OS: Ubuntu-Based distros, 9.04 based or better
VMware: Workstation 6.5.9+ and players 2.5.+
AC version: 13
Hardware 1:laptop
C2D T7400
4gb ddr2-800
Gf 7950 GTX 512mb ddr2
1920x1200 LCD (takes a faster video to run a higher res screen)
HD 7200rpm SATA-3
Looks good, 3d is totally acceptable, though it's a bit like using a Gf7600-7800 at best (drop in FPS about 40-45%). Turn on opaque surfaces (windows and doors can't be seen through) and this rings the FPS up about 20%... AVOID realistic or bmp/jpg backgrounds- this will cut the FPS way way down. So far nothing else is important for good 3D.
Hardware 2:desktop
Quad-Core 9550
8gb ddr
7200 rpm SATA-3
Gf8800gtx 786mb
Looks great, unless I'm working in MEP with 3d and big skyscrapers with a lot of non-opaque glass. Again, remove backgrounds (solid color is best) and keep the detail architecture light (sinks, pipes- hide those layers!!!)... Totally passable for work!
So for those of you with IntelMac's or such running Wine or Linux distros who want to switch more and more away from windows systems, we're ALMOST there. AC is very gear friendly in 3D and VMware (the best virtualization in my book, and I use or have used all of them) is right on the edge of crossing the gap for 3D stuff. I recommend DL the VMware workstation or player (I think they do demos) and try your ArchiCAD out in Linux!
It's not fast enough for me to switch over full-time, but with a fast machine, the excuses are becoming more scarce to keep using a windows machine!
Also not tried this with Crossover Pro.
I'll try it out sometime in the other distros I have
(Mandriva, OpenSUSE, CrunchBang, Mint and Debian)
Graphic card need bigger memory.
hi JP, do you have any experiences with ArchiCAD under Wine?
thank you a lot
peter
ArchiCAD working with Wine only in 6,5 - 7.0 versions.
