MEP ADD-ON
Good Morning
How I can give a slope on a total pipe system? using the new MEP module from Archicad.
11 Replies 11
David Maudlin
gpowless wrote:
As well we seem to be missing grills and floor registers that become part of the MEP system. In designing a system we always start with the outlet and work backwards to the equipment. Calculations for residential projects follow the same pattern. So each part of the system is required from the grills to the plenum to the drop.
gpowless:
Select the Duct Terminal Tool, and within the MEP Library look inside the folders in the Air Terminals folder. There are Floor, Ceiling and Sidewall registers and grilles.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
gpowless
David wrote:
gpowless:
David
Not even close to what we need.
Intel [email protected] 16g
