Hi to all.
I would need a help from MEP users.
Look at the attached picture.
I have a straight pipe line from level 0.00 to level 1000mm, from discharge point to a floor clean out. This is not a problem because:
1. I place the floor clean out in plan and set the correct level
2. start a routing from level 0.00 directly to the floor clean out. Mep Modeler does the job, making the pipe line with the slope to reach to the floor clean out.
I put a "Y" insert at a certain point of the line.
Now I need to follow a path to reach a floor drain.
I'm not able to do it. I mean the result I get is not what I want to get.
Can somebody help me explaining the procedure step-by-step?
It seems a so basic and simple task but I cannot figure out how to get what I need.
Thanks for your time.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
