Lee Hankins
Make editable an xref’d DWG
We have a DWG file from a client for a site master plan. It has several other DWG files xref‘ed in to
it but it has not been bound before exporting to us. Does anyone know a way to explode the DWG to make the entire file editable?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
1 Reply 1
Not sure if I'm missing the exact point, but you can select an instance of an XREF'd  DWG, right click, explode (maybe it's break not explode).
Just make sure your suspend groups toggle is not enabled.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
