Chadi SAROUFIM
Marker Settings and Calculation
How can I extract and show in a door schedule the "Custom door ID" that is specified inside the "marker settings" of a door?
Chadi Saroufim, Assoc. AIA
M. Arch & M. Urban Design, Partner
Idepconsult – Mounir Saroufim and Partners
ArchiCAD 23 INT
Windows 11
3 Replies 3
Link
Add the Marker Text to your Schedule Fields.
Link.
That Field selection does not work for me. Attached is what I get.
Right. Marker Text will read as 'custom' in your situation. You need to display the custom room and door fields. Unfortunately, it does not display the correct value in 10 (what you seem to be running) or 12 (which I just tested also) for the Door Marker NCS which it seems you are using.
Attached are the steps that SHOULD work, but which do not.
Karl
