MPHz24
Door Marker Position AC28 vs AC29
When I open a model created in ArchiCAD 28 in 29, all the door markers' positions go crazy.  I edit them in the Door Selection Settings, but when I press 'ok' nothing changes.  The marker isn't anywhere close to the door & the pop-up menu that usually allows me to edit the position on the screen does not let me move it vertically.  The part was originally created by saving a copy of a ArchiCAD 23 default marker, & has worked flawlessly up until this point.  Any tips or hints would vibe greatly appreciated.
In the PDF file, you show the Door Marker settings. Can you also show the result?
I am wondering if it is feasible for you to save the Marker under a new name into the Embedded Library, then open it for editing, and set its default values for the desired values. Then, in the future, you would only need to select the Marker from the list of available Markers, and its would appear exactly as you want.
