2026-01-11 08:42 AM - edited 2026-01-11 08:51 AM
Background
I tested out AC 28 and noticed some changes in the Settings Dialog of the Detail Tool compared to AC 26, namely
Issue
Questions
I've searched the web & this forum for more info related to this issue without any luck, so any help would be greatly appreciated, thanks in advance
-John
Operating system used: Windows 10
Solved! Go to Solution.
2026-01-11 12:19 PM
The parameters of the Detail Marker will depend on the library part used. I am assuming that you have the "Built-in Detail Marker" selected in the "Marker" panel of the Dialog. Try to select another one, like "Detail Marker 01", which has the option you are looking for.
2026-01-11 12:19 PM
2026-01-11 02:03 PM
Thanks Lazlo, that was indeed what i missed.
I missed it because in AC 26 INT default template, the default is "Detail Marker 01", and i never changed it to any other Type, but in AC 28 INT and its Global Library, "Built-in Detail Marker" is the default, thus when i did my test-run using my precisely documented steps i didn't even think to check which Library Part was used by the Tool.
Related to my other question, this might just be my oversight and too small a thing to be included in the main release notes, but could you maybe point me out to a link which lists such small changes as this one?
-John
2026-01-13 02:03 PM
I am not aware of such a list, sorry.
