Gabor,
I am enquiring more about the development/future of maxonform rather than the mactel version. Will it soon be possible to apply different materials (if only as basic refferance colours) to a maxonform model. I have cinema4d and do not use maxonform as it forces you to have your object all one material which makes it quite useless for me - the 3ds import/export plugin for archicad has supported multiple materials for years - why is the maxonform plugin so limited? Also it would be of great benefit if you could import 2d lines dwg into C4D/maxonform as archicad is much better at creating 2d profiles but C4D is much better at actually using them to make 3d objects. I assume you are in contact with maxon, could you investigate this possibility please. If those 2 wishes came true then it would deffinately be the answer to a lot of problems.
Thanks, Rob
