Mesh Generator by Master Script
With the Mesh Generator you can easily create meshes of any kind, blobs, soft objects, free forms. With the Mesh Generator you just draw the sections, preview it in 3D and convert it into a ArchiCAD mesh.
During BETA stage for extremely low price! CHECK IT OUT!
37 REPLIES 37
vfrontiers
vfrontiers wrote:
Sorry...is this for AC14 only?
Guess I should have gone to the website first... Yes, it would appear AC14 only...
Still can't wait!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
My attempt to model the Burnham Pavilion by UN Studio. Download sample textfiles from the website.
After generation I had to cut out a bit. Then did some SEO to get this result.
Its compatible with AC14 (and higher)
Traditional Dutch wickerroofs can be made too: Mesh Generator
After generation I have made another piece to cut open the windows and use SEO to complete it.
I have moved this thread to the Other Products category because in the Ads forum they will be deleted after a while.
I think this info and screenshots are worth preserving.
very cool
vfrontiers wrote:
I wish I could swear on this forum....
Freaking incredible.... Can't wait to get my copy....
Yeah - I'm swearing right now
€60 is not too bad
I'm wondering if the v14 mesh functionality always had this intended consequence - building the groundwork for a v15 feature perhaps. In any case I may very well spend the €'s.
Mats_Knutsson
Mentor
FREAK OUT!...
Very well done! Said before I tried...😉
AC 25 SWE Full
Dwight
And me, too!!!
Even tho i am passing a kidney stone, this thing is fun to play with and solves a big Archicad modeling problem.
Congratulations, Jeroen!!!!!!
Dwight Atkinson
New option in the Mesh Generator:
When the option Generate lower surface is on, a thickness can be set. Generate 'Lower Surface'-schedule and a new mesh can be generated. The meshes can be substracted with Solid Element Operation, leaving a shell-shape with constant thickness.
Mesh Generator
