Yvonne
Missing model view option
Not sure why model view options go missing - is this a bug?
This has happened to quite a few saved views and I haven't changed any settings within the model view options.
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
11 Replies 11
LucaP
I've encountered similar behavior (on a TW File) and after some investigation I thought that I've found the cause of this (issue with accidental MVO changes without reserving them).
Here you can find a discussion about it: Re: Missing Model View Options - Graphisoft Community
What is strange - I've got a response that there supposed to be a fix for it in AC 25 update 4, AC 26 update 2 and AC 27. You seem to be working on AC 26 - perhaps you need to update your AC (?). Keep in mind the solution mentioned by Laura Yanoviak in above-mentioned discussion - for files created in previous builds (cumbersome process of Open and Repair, manual MVO fixing and resharing TW file...)
Łukasz Pietraszko
ArchiCAD 28 PL, since AC20 | WIN 11 Pro
Intel Core i7-14700K 3.4 GHz | 64 GB RAM | NVIDIA GeForce RTX 4070 SUPER 12 GB | 2 TB SSD
ryejuan
Thanks for sharing, let me try that approach in saving and repairing the file... Not sure if the cause of it is the template that was carried over from version 20 and was upgraded as version release comes...
Am also using the latest updates for Archicad 27... Still contemplating if I want to shift this project to Archicad 28 though...
WINDOWS 11 PRO
