Multiple Survey Points
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-08-17 11:43 AM
‎2020-08-17
11:43 AM
However, afaik for IFC Export only the first (?) placed SP is taken into consideration and defines the IFC Origin. Is there a way to choose (or activate/deactivate) which SP should be used for exporting?
Labels:
- Labels:
Data Exchange
15 REPLIES 15
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-28 06:34 PM
‎2020-08-28
06:34 PM
Here is the missing screenshot of the line I wrote in cyan:
BTW: Have I already mentioned how painful it is to post media content here on the forum?!?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-31 11:53 AM
‎2020-08-31
11:53 AM
Hi there,
Hmm...that is very strange to see. Since I'm not quite familiar with how Revit exporting the IFC with SP, could you share the IFC file with me for further investigation? As always, if you need a secure address to upload your file, please let me know!
Thank you very much!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-31 01:27 PM
‎2020-08-31
01:27 PM
mnguyen wrote:Hi, I sent you the file via a private message. Thx.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-09-14 07:15 AM
‎2020-09-14
07:15 AM
Sorry for the late reply! We just had a chance to discuss this issue with the development team. Whenever we use 'hotlink' to import an IFC, it doesn't consider the position of the survey point (yet).
If we use Merge, on the other hand, the Survey point in the IFC file is automatically pinned together with the survey point in the Archicad file. In case if there's no survey point placed in the project, the Archicad project origin behaves as a survey point (it's a hidden SP basically).
So I would recommend merging the project if that's acceptable. If you need hotlink instead, you may want to adjust the height of the placed hotlink, which can be done by setting the Offset value within the Place Hotlink dialog.
Please let me know if you have any further question!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-09-28 12:00 PM
‎2020-09-28
12:00 PM
mnguyen wrote:So to be precise and sum it up you mean it does not consider the Z-Position when hotlinking and this is the usual behaviour? When you write (yet) in brackets does this mean that this is going to be changed in the future?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-09-28 12:54 PM
‎2020-09-28
12:54 PM
We are considering how to best implement Survey Point in IFC exchange. This is definitely not the final design. We will keep improving the functionality of IFC exchange, so this one is surely something that we want to refine in the future!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
