2010-10-04 11:47 AM
2010-10-04 03:47 PM
2010-10-04 03:54 PM
2010-10-04 04:22 PM
2010-10-04 09:22 PM
2010-10-08 02:57 PM
Matthew wrote:IIWAL!
Your associate is right. IFC into Navis is pretty bad. DWG is better. NWC is best but as you've noted the export add-on is only up to AC13 32bit so far (I expect we'll see AC14 and 64bit support with Navis 2012 next year).
If the DWG works for you, as Erica suggests, you can fully automate the process by setting up 3D views and publishing the models that way. This makes it a one click process which is a big benefit compared to having to save the NWCs manually.
If you really need NWC output you have to save back to AC13 and run it in 32bit.
FWIW: Revit still does a lousy job saving NWC and everyone I know still uses DWG to go from Revit to Navis.
2010-10-08 05:48 PM
