ā2022-06-24 11:40 PM
Hi in the publisher, the only option I have besides PDF to publish to is BIMx. I checked the Add Ons menu and DWG input/output is checked. Not sure if I am missing something - thanks
Solved! Go to Solution.
ā2022-06-25 08:45 AM
Have you created the publisher set necessary to publish DWGās? You need to create a new publisher set and change the settings to DWG. There should be a button under the publisher settings in the navigator to change a new set.
ā2022-06-25 09:40 PM
Got it - I guess I had to create a new set. It wouldn't let me edit the existing set. Thanks !
