brittsax
No option to publish to DWG
Hi in the publisher, the only option I have besides PDF to publish to is BIMx. I checked the Add Ons menu and DWG input/output is checked. Not sure if I am missing something - thanks
AC29 USA • Apple M3 ultra | 96 GB • OS Sequoia 15.7.4
1 Solution
Lee Hankins
Have you created the publisher set necessary to publish DWG’s? You need to create a new publisher set and change the settings to DWG. There should be a button under the publisher settings in the navigator to change a new set.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
2 Replies 2
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
brittsax
Got it - I guess I had to create a new set. It wouldn't let me edit the existing set. Thanks !
