2014-06-11 11:43 PM
2014-06-12 01:47 AM
2014-06-12 01:50 AM
2014-06-12 02:03 AM
2014-06-12 02:09 AM
2014-06-12 02:10 AM
ejrolon wrote:
As I said in the first post this might be a problem with your Work Environment Settings. If you bought the template from Bobrow you will need to get in touch with him to help set it up again.
If not you can go and reset your work environment by going to Option->Work Environment-> Work Environment-> Tool Schemes and select standard
You should save the current one just in case you have configured shortcuts etc.
2014-06-12 02:14 AM
Jonathan wrote:
Here is another screen shot showing the id I entered, but karl was saying
(above) that you can't use a custom ID for some reason.
If this is true than how does one get the doors and windows to be numbered in a logical sequence in plan "each door and window needs to have a separate id and be in a logical direction around the plan.
Jonathan wrote:
Eduardo,
Here is a screen shot of my project map tree under schedules.
I tried opening many if not all of these and there didn't seem to be any relation to my numbering? In the screen shot you can see my first window is window A and all the fields are exactly like the one you provided.
I don't see anything in there called ES window schedule?
ejrolon wrote:
JP, the Window Schedule resides under schedules in Navigator Map. Look at the first image I posted it is above indexes. The Markers are the Dimension Marker for the windows.
If it helps think of the schedules as MS Excel Tables that pull data from the objects that you choose in the settings.
2014-06-12 02:19 AM
2014-06-12 03:05 AM
Richard wrote:
This tutorial of Bobrow's may help in renumbering the windows: Window Renumbering
2014-06-12 03:21 AM
2014-06-12 04:08 AM
Richard wrote:
JP,
Try going to YouTube and searching for something like "Archicad Window Schedule." There are a bunch of video tutorials there. It's a very good resource for something like this.
