Not being able to import the .3ds file into ArchiCAD
I made a particular 3d model in Rhino, and exported it as .3ds (9.5 MB in size)
I tried importing into both ArchiCAD 12 and 14 using the
Import 3d Studio file add-on, but it did not work. The conversion to .gsm seems to went well, but when I put that .gsm file into the floor plan, I am get nothing. Just a dot.
I used to have the same problem all these years, but mostly in cases when initial .3ds model has some curved shapes. But this one is different - it is mostly consisted of straight parts.
The second thing I tried to do is to export the model from Rhino as .skp (Sketchup file) and then import it into ArchiCAD 14.
Did not work - apparently the importing procedure ended by nothing was imported.
The same thing with .kmz (Google Earth) and .dwg
In the end I might try importing the .ifc, although I am currently looking for an export IFC plugin for Rhino.
It may sound strange, but I did not get any error message when entering into the 3D view.
Could I ask you for a favor? Would you be so kind to attach the .gsm file? The one you succeeded importing into ArchiCAD 16? I guess the .gsm file from ArchiCAD 16 would work on ArchiCAD 14 too, right?
I have opened the file in Cinema and saved as 3DS. I converted it in Archicad to GSM as a test. I attach the saved 3DS file that should import into Archicad, renamed as "youowemebigtime" and have sent it to your email.
