Numbers format in schedule cell
is there a way to change the format for numbers in cell?
for instance, adding a point as thousands marker.
12 Replies 12
alemanda
I think it depends on the international settings in you operating system.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Already checked, Archicad doesn't take the format from them.
Eduardo Rolon
FYI, in MacOS X it does.
Don't know about Windows.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I'm using Mac OS X and it isn't getting the format from the international settings. Anyway it should be editable my settings are not necessarily the way the client is asking for their schedules
Eduardo Rolon
Sadly it cannot be controlled separately.
Under Preferences ->Language and Region->Advanced->…
Restart Archicad for changes to take effect
There you can add any item as a thousands separator provided though AC might just recognize the basic ones (, . ')
AC29 US/INT -> AC08
Eduardo Rolon
AC29 US/INT -> AC08
Eduardo Rolon
and in AC.
FYI, this is where I change my short date to match 20XX-XX-XX
AC29 US/INT -> AC08
Eduardo, thanks for the tip, but my setting was already the way i needed to be, the problem is AC not getting them.
I´m using the standard "cost" parameter from basic AC library parts, when i try to write the cost of a product using the point AC deletes it automatically.
When it comes to other numeric parameter like Area, it works perfectly with the thousand mark.
This is another schedule using area from zones
