SOLVED!
OBJECTS SIZE IS NOT EDITABLE IN SCHEDULES/ ELEMENTS SCHEME in ARCHICAD 21,
levonarsh
In previous versions it was not a problem to edit all dimensions of the objects in schedules/ elements scheme . In Archicad 21, I tried to change the height of an object, ( as I have done it all the time in previous versions ) but it is not editable now, while the other 2 sizes are still editable. I need this option very often. Why is it changed, or it is simply a bug ?
12 REPLIES 12
levonarsh
Thank you for comments. I'll try to open AC11 file in AC 20,first, save, and then open in AC21.
If you have access to the original SKP files, you should probably import those in AC21, that would probably be the most straightforward. Of course, if you do not have access to them, you need to try those other options.
levonarsh
The problem is, that, when importing into AC 21 the SU scene comes as a one whole GDL object, while importing in old way with SU add on into AC 11, I get from each component a separate correct gdl object with it's right name and layer. This is very important for my job.
