OSX c4d plugin
Hello brains trust,
Did anyone have ANY luck installing the c4d exchange plugin for AC10 under OSX?
I downloaded the update from www.maxon.net and followed the PDF istructions. ArchiCAD seems to simply ignore the new plugin.
It odesn't show in tha add-on manager, and can't be loaded manually.
I tried all sort of tricks, different loactions in the add-ons folder (there are other add-ons with similar file structure to the c4d one - spellcheck for example) and still nothing.
Please help, especially considering that I went to MAC because it has been rammed down my throat how "things just work"...
Yours in desperation,
greg
22 Replies 22
Eduardo Rolon
Mine is working fine. What I did was the following
1. Copy the C4DExporter file into the Import-Export Folder of AC10
In C4D it was a little more complicated since Maxon changed the extensions of the previous plugins but the procedure was the following
1. If C4D R9 installed copy the Archicad folder from the plug ins folder to the same folder in R10
2. In the AC folder erase the the 2 files named ArchiCADImport and copy the new ones.
Done
Now it should work
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Tom,
OK, will not post anymore.
As it is an upgrade, did you do anything o the previous version plugin? Do you have a plugin file called "Cinema4d" within the V10?
Yes, that is exactly what I did to install it.
The AC4D does not show up in 2D or 3D window under File/SaveAs
Does Cinema 4d show up in your addons manager?
Any help is greatly appreciated.
BTW QT7 seems to be an Apple product and it can give you grief as well
Burginger,
Thanks for your interest.
There is no plugin icon in the finder.
I have the old plugin file called "cinema4d" which has the jigsaw/plugin icon.
The upgrade only gives me a folder structure with "unix executables" with gray icons. this will show you the file structure I have: http://www.geocities.com/iqnill/
Thanks again to all trying to help.
And a wink and a nudge to those who just ask irrelevant questions and disappear, you are important to me, without you the forum would be small and boring.
greg
Oops, I meant, will not CROSS post aymore
g.
Gracias Eduardo,
I am on an Intel based MAC.
I did try to copy the CD4Exporter into Importr/Export and In the Add-ons manager i get the red excalmation mark icon, and it says "The file is outdated ... cannot be used with this version of ArchiCAD"
I tried all of above on build 987 and 1010 INT, all the same...
The CD4Exporter sitis in the PPC folder only (as in, there is no such file in the Intel MAC folder) and the instructions say to copy the folder appropriate to the platform.
Still lost..
Greg
Maxon says to contact them via tech support.
Thank you, I will.
It will take me some time to put all the info together for them, but I will keep you posted.
greg
Djordje
g.
... and you owe me a mocha for tracking you all through the maze 😉
Now all the relevant posts are here, so post only here on this topic.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Well DJ, is it a new record?
Now that all of that is behind us. Would those who have the C4D plug-in operating properly post a message as to how it works?
Thanks
How do you have your mocha DJ?
Will this do for now?
I promisse I will behave from now on.
greg
OK, contacted MAXON tech-supp... now we wait...
all details here:
that's the link I gave to the MAXON people.
Thanks to all, again.
And my special thanks go to Dwight for his warm welcome and words of advice - I wave back at you brother.
greg
