‎2005-05-04 08:33 PM
‎2005-05-05 01:28 PM
‎2005-05-05 03:02 PM
Fmr wrote:Hi Fmr,
Bonjour Olivier
Which kind of object is concern by your demand ?
‎2005-05-05 05:44 PM
‎2005-05-05 09:08 PM
Fmr wrote:Thanks Frédéric. Yes it is an "object", using some SEO and macros for accessories.
Is your parametric pool really an "object" ?.
Fmr wrote:That's what i do since years, but what a pain.
If it is, you can in your parametric script calculate —by using your parameter to arrive at this result — the tile area of your spool.
This result is stock in one parameter that you can print inside your object or extract with the interactive schedule.
The tile area will evolue each time you modify your "object" pool..
Fmr wrote:Yes it works, but i am hoping for an automatical calculation. I asked François, he doesn't seem to have a solution.
This solution is not the easier —you need programming the calcul of the tile area inside your object— but I think that it works….
