2022-09-13 12:19 AM
I have the same question as this user: https://community.Graphisoft.com/t5/Collaborate-forum/Can-an-object-placed-in-elev-show-in-IS/m-p/19...
But the post was from 2006, and I am wondering if it's still true for A24?
I have a 2D object being placed in a section/elevation view, but it is not showing up in the interactive schedule made for it. If I place it on the floor plan it does show up. How can I get it to show up in the interactive schedule if possible?
Thanks
Solved! Go to Solution.
2022-09-13 03:03 AM
Only elements in the 3D model or floor plan will show in a schedule.
Nothing you place in the sections, elevations or details will be included.
All I can suggest is you add a copy of those objects to the floor plan in an area or layer that can't be seen.
It just means you will have to manually manage the duplicates.
2022-09-13 03:03 AM
2022-09-13 03:09 PM
This was the workaround I had figured out. Thanks
