Objects in elevations/sections not showing up in interactive schedules
ocamorlinga
I have the same question as this user: https://community.Graphisoft.com/t5/Collaborate-forum/Can-an-object-placed-in-elev-show-in-IS/m-p/19...
But the post was from 2006, and I am wondering if it's still true for A24?
I have a 2D object being placed in a section/elevation view, but it is not showing up in the interactive schedule made for it. If I place it on the floor plan it does show up. How can I get it to show up in the interactive schedule if possible?
Thanks
AC 24 US
Windows 10, AMD Ryzen 7 3700X, 16.0 GB Ram, AMD Radeon RX 5700 XT
Only elements in the 3D model or floor plan will show in a schedule.
Nothing you place in the sections, elevations or details will be included.
All I can suggest is you add a copy of those objects to the floor plan in an area or layer that can't be seen.
It just means you will have to manually manage the duplicates.
ocamorlinga
This was the workaround I had figured out. Thanks
AC 24 US
