Thanks a lot guys,
First of all, I'll let you know that my english level isn't a good one, I hope you'll understand what i wrote.
Your advices and ideas are very helpful. Yes Karl it is possible if I use the list, but only the text list format can give all the values for the array parameter, like you can see in the attached pdf files. The problem is that the tabel can be set it to display only the rows format. I'm wondering why if I use the graphical template I can't see all the values, it will be displayed only the last value(maybe the first i don't remember now, anyway it is just one.)
I can write a script to display a tabel wich will contain all the values and informations I need from the object and I can set it as 2d symbol if the GLOB_context is (list or schedule). In this way it can be scheduled, but I have to reorganize the height of the row in schedule, considering the fact that each object can have different numbers for array parameters.
Or I can follow alemanda's idea.
Also I was wondering if it's possible if I use the ARCHIQUANT add on. Is there anyone who is expert in ArchiQuant?
P.S. And yes, the object example is -Surface legend 17-.
Again thank you all.
AC24
•Workstation HP Z800 2 x Intel Xeon Quad Core E5620/E5630, 36 GB ram DDR3 - NVIDIA QUADRO 4000 2 GB memory, Windows 10 pro
