2009-01-02 10:06 PM
 ! Can I get overall number only for such non-oriented doors from standard ArchiCAD library (AC 12) without changing GDL code for them?
 ! Can I get overall number only for such non-oriented doors from standard ArchiCAD library (AC 12) without changing GDL code for them?2009-01-03 07:44 PM
Leo wrote:There's a separate field for the quantities in your scheme settings. Go to scheme settings. One of your fields will be Quantity and one will be ID.
I am sorry, Wrathchild, but we are talking about quantities, aren't we? Empty ID field can't solve the problem with countable fields
2009-01-03 07:53 PM
2009-01-03 08:06 PM
You would have to have separate rows for RH and LH doors. Not sure if you can live with that or not.Unfortunately, I can't go with it. I have to put quantities of left/right opened doors and overall quantity of this particular type of doors on one row.
2009-01-03 08:09 PM
Leo wrote:I agree. It is a bit embarrassing for GS that doors store so much parametric information, and yet one cannot retrieve the swing orientation. The LHS/RHS info could be easily computed by the door objects - which have to take into account their own 'mirror' and 'flip' status - yet it is not. Scheduling the swing is a pretty basic concept, and I agree with you Leo that it should be computed from the model, not retrieve from manually entered data fields which can easily become incorrect.
At first, ArchiCAD already does a lot of work for us when it let us to set door's swing visually. Why should we ignore this information?
There are three cells in each row for quantity: quantity of left-swinged, quantity of right-swinged, and overall quantity.ArchiCAD will let you create a group header for each of the three types of door quantities, but each total would appear in its own row (three rows). I don't know of a way to get ArchiCAD to directly generate a single row with the totals in three columns - other than publishing the schedule as CSV and letting an Excel pivot table (or database query/report) reformat the data.
2009-01-03 08:19 PM
		2009-01-03 08:48 PM
The LHS/RHS info could be easily computed by the door objects - which have to take into account their own 'mirror' and 'flip' status - yet it is not.Thank you, Karl, for your answer. But I thought that "W/D opening orientation" field in List Schemas worked well for oriented doors. According to my experiments, the field changes status after flipping, mirroring e.t.c. Why did you say that this functionality haven't implemented yet?
2009-01-03 10:19 PM
2009-01-03 10:22 PM
2009-01-04 10:59 PM
		2009-01-06 04:15 PM
