Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
SOLVED!
Override Window Surfaces in Window Schedule
Is it possible to override the surfaces of window elevations in the window schedule so they are line drawings or blank fills instead showing their surfaces?
1 ACCEPTED SOLUTION
Solution
This is what I have set up (see attached image).
You then apply this 'Schedule' Go to the views of your schedules in the view map (or if you are just viewing a schedule on screen make sure this GO is active).
4 REPLIES 4
Yes with Graphic Overrides.
I don't have Archicad running in front of me at the moment for the exact settings, but you need to override the fills in a new 'Schedule' GO combination and then apply that GO combination to your schedule view.
Barry,
I have created a "Door and Window Schedule" graphics override, but cannot find a "Schedule" criterion to which I can apply the override. I have tried also selecting "All Types" but the schedule looks the same.
Solution
Barry,
Thank you so much. It worked.
