PLT -> PDF converter for Mac OS X
So anyone knows if there's a program for OS X that'd convert PLTs to PDFs?
13 REPLIES 13
Mark Wallace
Open the .plt file with 'GraphicConverter.' It's been bundled in with other Apple operating software for several years.
If not bundled; it can be located here: http://www.lemkesoft.com/
Open the file, then print as usual, using the 'save as PDF' feature.
I use this every now and then for HP files or other plot files for converting them to PDFs.
Hope this helps.
Mark
Mac G5 Dual 2.3 Ghz, 1.5 Gb, Mac OSX.4.11, ArchiCAD 12 2782 USA Full + 11, 10, 9 & 7
Mark R. Wallace AIAa
Mark R. Wallace AIA
MacBook 2.53 Ghz, Intel Core i5, 8 Gb,
Mac OSX (Sierra 10.12.6,
ArchiCAD 22 USA Full, +21, & 20.
If you pay the shareware fee (highly recommended) you can also batch process files. Graphic Converter is perhaps the greatest piece of shareware ever.
I just copied this to the Tips forum ... but then followed the link and do not see PLT as a supported format:
http://www.lemkesoft.com/content/143/import-and-export-formats.html
Could you verify if the current version allows for the conversion?
Thanks,
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Mark Wallace
I have version 5.4.1 Rev2 dating back to 2005.
It opens .plt files just fine; Including ones generated the other day.
Edit; just checked the page link above and down the page is;
"HP-GL/2 Vector images. This format is normally used from plotters."
End edit....
Every now and then I get a plt instead of a pdf from a contractor and this program opens them up and displays the graphics just like a pdf.
It's a real 'can-opener!'
Mark
Mark R. Wallace AIA
Mark R. Wallace AIA
Great, thanks Mark!
Eduardo Rolon
CorelDraw used to be able to do this also.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Brad Elliott
Why not just open them in ArchiCAD? Then you can do what you want with them.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Mark Wallace
Ah....in versions of ArchiCAD before V10, where plotmaker was a stand alone program, plt files would not import accept as gibberish if you could get ArchiCAD to open the .plt at all.
Since we no longer use plotmaker, I never thought to try ArchiCAD. In doing so, it appears that Brad's suggestion really works!
ArchiCAD is indeed an interesting graphic utility as well as a CAD/BIM design program.
Mark
Mark R. Wallace AIA
Thanks, Brad.
