PROBLEM SAVING FROM ARCHICAD 10 AS A DWG FILE
Hi, im new here but i have a bit of a problem. ive created a file in archicad 10 and im trying to save it as a autocad file but it tells me cant write output file(only on first floor , base level happens). where can be the problem. please help.
1 REPLY 1
Hi!
Propably there is some kind of Xref or Hotlinked modul in your model which is disturbing the "save as" to dwg.
Perhaps you have merged or attached a DWG in to your model which in it self have had an xref´s attached to it. Those xref´s tend to get stuck in your model.
Solutions - detach, remove and erase all unknown xref´s and try saving again.
We have had success with this.
Good luck!
