PROBLEM SAVING FROM ARCHICAD 10 AS A DWG FILE
Hi, im new here but i have a bit of a problem. ive created a file in archicad 10 and im trying to save it as a autocad file but it tells me cant write output file(only on first floor , base level happens). where can be the problem. please help.
Hi!
Propably there is some kind of Xref or Hotlinked modul in your model which is disturbing the "save as" to dwg.
Perhaps you have merged or attached a DWG in to your model which in it self have had an xref´s attached to it. Those xref´s tend to get stuck in your model.
Solutions - detach, remove and erase all unknown xref´s and try saving again.
We have had success with this.
Good luck!
