Parameters for listing
Hi
Attached is a screen shot of door parameters for listing. Does anyone know if and how you can change them?
Thanks
12 Replies 12
Laura Yanoviak
The blue font indicates it is a parameter from the Subtype (so you need to go into the Subtype to change/rename).
Laura Yanoviak
Grant wrote:
IHow do I get to the parameter screen. I can get there with Cadimage doors but not archicad doors. File>Libraries and Objects> Open Object...
Same procedure for AC doors -- if you have the desired door selected when choosing Open Object (or Ctrl+Shift+O) the part will open, and you don't need to go looking for it.
If your Library is loaded as a LCF, you will either need to rename the part to save changes, or extract your Library in order to overwrite it.
Great. That works. Thanks a lot. So easy when you know how...
