Pirenasi export
Having trouble exporting an Epix file. The export goes fine until about 3/4 way through the "exporting z channel", then just sits thre and task manager says archicad is not responding. Waited for a good 15 minutes. Still nothing. File is 28 meg. I've tried to marqee the area I need only, but same thing happens. Any thoughts?
Brian Witteman
Deep River Partners
Archicad 8.1, Dell optiplex gx280, pent4 3.4Ghz, 2 Gig Ram, ATI Radeon X300
I never could get 8.1 to put out a epx file. I always had to go through Artlantis. One thing about going through artlantis is that it is easy to quickly assign textures etc. and then soften them up with Pirenasi.
David Pacifico
I do believe the 8.1 Piranesi Out was not great. It was improved in 9.0.
If you have Artlantis, It produces a good Piranesi File.
You might try making your 8.1 rendering size smaller and or less complex.
You might also try saving your ArchiCAD Rendering as an image say a TIF and using Piranesi / File/New Create an EPix file from an Image file.
An Epix file is a TIF with additional information. So you will not have the additional information ie: Material and Depth, but it might serve you in a pinch.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
